Is there a app that I could add to my I phone 6 plus or my mini I pad that would help when running live sound? Thanks
by sjc193 on Tue Nov 08, 2016 2:20 pm
It depends on which 16.4.2 you have. The classic? or the AI? The answer is yes for the iPad Mini either way, but the means of making it work would be different depending on exactly which model you have. The iPhone doesn't really work for live sound, just monitor mixes.
Steve
StudioLive RM32AI
ASUS RT-N66U Dual Band Router
4 EV ZLX-12P's, 2 Yamaha S115V's
4 Behringer EP2500 amps, 1 QSC Amp
10 58/57 mics, 1 AT2020, 2 AT2021, 1 beta52 kick mic
2 e609, 2 Radial J48 DI's
by sammycat on Tue Nov 08, 2016 4:40 pm
It's the classic
by wahlerstudios on Tue Nov 08, 2016 5:22 pm
StudioLive Remote and QMix is what you need. Have a look here: http://www.presonus.com/products/Control-Software
SL16 | 32R | 16M
Apple routers | iPads | PreSonus SW5E & Motu AVB switches | Alesis iO Dock with AudioTools' Smaart RTA & Spectograph extension |
Yamaha S112, S15e, S10e, SM12, SM10 | Galaxy Audio Hot Spots | Mac mini | Lenovo Laptop | Studio One Pro 3.5.6
by sjc193 on Tue Nov 08, 2016 5:33 pm
With a classic studiolive, you have to have a computer with FireWire (Mac mini is a good option, maybe used on eBay even) to use SL Remote on an iPad or Qmix for the iPhone
Steve
StudioLive RM32AI
by sammycat on Wed Nov 09, 2016 9:06 pm
!s It possible to down load a pink noise and a smart to my I phone for tuning the room and ringing out the monitors as you know the 16-4-2 has 6 built in 31 band EQ's ? Thanks!
by sammycat on Wed Nov 09, 2016 9:08 pm
2- 31 for the Mains too,.
by wahlerstudios on Thu Nov 10, 2016 5:51 am
There are several tools available. You might want to have a look at http://www.studiosixdigital.com/ and their AudioTools. You can buy Smaart as an add on, but also without it's a phantastic help for live work.
SL16 | 32R | 16M
by sjc193 on Thu Nov 10, 2016 10:00 am
I use a free app called SpectroPro on my iPhone for ringing out monitors/mains with the GEQs. If you adjust the sensitivity right, works great! And can be used with any PA, I've brought many smiles to faces of other sound guys by showing them that App and how to use it! Anyone can crank a mic till it feeds back, but to instantly know exactly what frequency that feedback is, that's sweet!
The Smaart wizard of the StudioLive can only be done through SL Remote on an iPad (mini works) and it affects the PEQs of the outputs.
Steve
StudioLive RM32AI
by sammycat on Thu Nov 10, 2016 12:54 pm
Thanks Steve, That's exactly what I'm looking for!
by sammycat on Thu Nov 10, 2016 1:02 pm
Hey Steve would this App be called Spectrogram Pro? When I did a search this is what came up.
by sjc193 on Thu Nov 10, 2016 2:17 pm
sammycat wroteHey Steve would this App be called Spectrogram Pro? When I did a search this is what came up.
Yes, That's it, Spectrogram Pro. The icon on my phone says SpectroPro so. . .
StudioLive RM32AI
by sjc193 on Thu Nov 10, 2016 2:22 pm
Re:SpectroPro
Start up the app, then whistle while looking at you phone and you will see your whistle in the spectrograph, then touch the screen where the hot spot is and it will tell you the exact frequency at that point!
Whistling works great as an example opposed to humming, humming/singing causes too many harmonics to be heard and it can be hard to tell what the root of the note really is, but a whistle comes through with no harmonics, and feedback typically shows the same way as a whistle.
Steve
StudioLive RM32AI
by sjc193 on Thu Nov 10, 2016 2:28 pm
Lots of things to tweak in the options (I'm not even sure what they all mean), I have my gain set pretty low like 15%, range 12s, Scale=log, S+B, Avg, spec, FFT 4096
but play around with it while whistling and get it to work the way you want it and it should work about the same way when ringing out monitors
Steve
StudioLive RM32AI
by sammycat on Thu Nov 10, 2016 3:25 pm
Thanks Steve, Just what I need.
