I recently purchased a roland tr8 and im new to the world of recording. I've setup my tr8 so that i can hear the sounds it makes through my pc so, i can hear it when i play with it. I wanted to try and record a simple track. the audio from each of the instruments is showing up sounds up in the bars so i can see that it is recording. but when i play the track it doesnt have any sound, and again i can see there is sound recorded. Can anyone help me? Im using the tr8 with just the DAW output, windows 10 thanks in advance |
I suspect a little more detail is required, when you DAW output...what is that exactly?
So assume you have created 2 audio tracks or 1 stereo track in S1, enabled record, and then play the TR8 and you see levels in the meters? If you then press record in S1 it will record that sound and then play it back, are you seeing any meter levels on playback? |
Users browsing this forum: No registered users and 87 guests
