Dear Studio One Users,
Studio One 3.3.4 is now available. This little maintenance update contains some minor technical fixes in different areas. Additional there is a new spanish manual. Have a nice pre- spring! Ari ________________________________________________________ Version 3.3.4 Release Notes (February 21, 2017): New features and improvements: • Trim start/end to cursor works for selected track if no event is selected • Unpack layers to tracks in the context menu on range selection. Also for specific layers (via range selection on layers) • Templates for StudioLive 32, Studio 2|6 and Studio 6|8 • spanish manual The following issues have been fixed: • [macOS] Crash when re-adding VST instruments • [macOS] AU automation broken for large param IDs • [macOS] Hang when zooming reference manual to small (mobile) view • [Win] Improved Direct 2D error handling • VST3 context menu position wrong on Windows High DPI • Audio engine error when activating Fat Channel • Global FX off can’t be switched ON when a track is deactivated • Fatal error in DDP export • Embedded Melodyne not working in Artist version • Crash when loading projects with missing media files • Channel splitter exposes noise of analog-style plug-ins
Skaperverket wroteCool, that's pretty neat. It's really great that Presonus pays attention to our feature requests. Watched the livestream, well sort of, with some delay due to Chrome crashing trying to log into chat! What happened to the old but easy login proceedure? Anyway... A big deal was made of Presonus 'listening to its users' and responding to the number One feature request 'fader undo' but failed to address numbers 2 & 3, which were both to do with CPU efficiency! Is that because the new 'low latency' stuff enables S1 to utilise cores more effectively? Maybe I missed something whilst messing around logging in to chat... Not sure I fully understand the consequences and complexities of 3.5 yet (not sure I'll ever understand fully) guess time will tell. Regards....
Steve Carter wroteA big deal was made of Presonus 'listening to its users' and responding to the number One feature request 'fader undo' but failed to address numbers 2 & 3, which were both to do with CPU efficiency! Is that because the new 'low latency' stuff enables S1 to utilise cores more effectively? Maybe I missed something whilst messing around logging in to chat... They improved they CPU balancing and performance. Haven't tried it yet, but it's in the release notes and is being talked about. Not only is balancing improved, they've taken steps to reduce dropouts and glitches too by the looks of things. Very pleased to see that stuff!
garryknight wroteSomeone posted over on KVR:I've been trying it out for the last hour or so and the global undo/redo works flawlessly in S1 itself and all the plugins I've tried (if the changes are made with a keyboard or a mouse, but not when the parameters are moved with a MIDI controller) I had a similar experience as a Nektar Impact LX49 owner. I updated to 3.5, and forgot to reinstall the Nektar drivers (sadly, a requisite action after every Studio One update). Oops. So I shut Studio One down, and reinstalled the drivers. Yet, still the Nektar's MIDI input wasn't recognized by Studio One. Drat! I reinstalled the Nektar driver again. I shut down S1, turned my LX49 on and off, and restarted S1. And then... it worked. Not sure what I did right, other than be persistent. You're not alone... but it can work. |
Users browsing this forum: patm300e and 83 guests
