Hello S1-Users,
it's still may and here is the second half of our spring cleaning. Have fun with all the fixes and the little new things. best regards Ari ______________________________________________________________ Version 3.2.2 Release Notes (May 19, 2016): New features and improvements: • New command to open Event FX window (Alt+F) • ALT modifier for fades now suspends crossfade editing • New option to enable/disable auto-expand layers after recording takes • Monitoring button and metering reflect correct status in tape-style record mode • Bus channel metering shown on automation tracks (track height “normal” or higher) • [Project Page] MD5 checksum for DDP export • View all channel types in inspector • Use ALT modifier to add FX plug-in as bus channel when dragging to console • Improved import of Cubase/Nuendo Track Archives (now supporting level, mute, automation data, VCAs) The following issues have been fixed: • Mix Engine FX have no latency compensation • Crash on quit with multiple open songs • Controller data not visible while recording on Instrument Track • [Music Editor] CMD modifier behavior for temporary Paint tool should be inversed • Crash after drag and drop of audio to the browser • Alternate range tool doesn’t work on automation lanes • Paste at original position doesn't work for arranger parts • Dragging multiple events to empty space doesn't create multiple tracks • Layer name not set on first take • Legato command misinterprets last event • Bus connection lost after adding VCA in track controls • Automation track to lane area not properly transferred on drag • Wrong channel order after adding VCA from track controls • [OSX] UAD plugins leave white boxes on the screen • [Presence XT] articulation key switches not applied for notes on same time-position • Impossible to set cursor to bar 1 beat 1 in Scratch Pad • Vertical zoom state not reset on double-click when all notes have the same pitch • élastique Pro 3 time-stretching out of sync in stereo files • "Solo follows selection" doesn't work for shared instrument tracks • Crash after undo audio quantize of grouped tracks • Play Start Marker placed in negative time • Delay Compensation broken for Pipeline on Main Out • High sample rates not represented correctly in OpenTL
