Console 1 works absolutely fine in S1. Just tried it. Softube has even made it optional to let you decide if you want automatic naming or numbering or prefer to do that yourself, e.g. to collect all tracks on one Console 1 screen. Too bad I prefer Reaper that doesn't have this functionality yet.
I can confirm, this last update just made Console 1 + Studio one the perfect daw for mixing imo. Only thing I'd love to see from Softube is to allow a generic mode for 3rd party plugins. I'm really digging the workflow for mixing in S1 now. Feels like a real console ,but with all the perks of ITB.
New here, hi guys. I have an issue with the Console 1 to Studio One 3 integration. I filled out a support ticket with both Softube and Presonus, but since it is the weekend, thought I would try here in case someone knows how to solve:
When I open a S1 project, my console 1 settings (EQ changes, etc) are not saved. Also, the plugin window does not function (I just see a C1 splash screen). For example, I have placed Console 1 as an insert on all channels and busses in my project. Initially, the plugin works fine, and I make a bunch of EQ changes, etc. I hit save, and close Studio One. When I relaunch the daw/project, my console 1 instances no longer function, when I open an instance, I just see the C1 splash screen, and my changes appear to be gone. Also, I cant make any adjustments, as the controls are no longer available. I removed and replaced the old C1 instances with new C1 instances, but the problem persists... when you close and later restart a session, changes are gone, plugin not functioning. I am using: Console 1 latest version from 10/21/16. I use the VST3 plug. Daw: Presonus Studio One 3 version 3.3.2.40899 from 11/25/16. Mac OSX 10.11.6 Anyone getting this issue? |
I have the exact same problem. anyone got a fix for ir?
Trechuck wroteNew here, hi guys. I have an issue with the Console 1 to Studio One 3 integration. I filled out a support ticket with both Softube and Presonus, but since it is the weekend, thought I would try here in case someone knows how to solve: |
NikkDust wroteI have the exact same problem. anyone got a fix for ir?Trechuck wroteNew here, hi guys. I have an issue with the Console 1 to Studio One 3 integration. I filled out a support ticket with both Softube and Presonus, but since it is the weekend, thought I would try here in case someone knows how to solve: exactly the same for me. I noticed last 2 days. maybe was ok 2 weeks ago not sure what has changed ? maybe was always happening and I didn't realise. was going to say maybe windows update but can see mac user has same problem. I am on windows 10. |
alexgick wroteNikkDust wroteI have the exact same problem. anyone got a fix for ir?Trechuck wroteNew here, hi guys. I have an issue with the Console 1 to Studio One 3 integration. I filled out a support ticket with both Softube and Presonus, but since it is the weekend, thought I would try here in case someone knows how to solve: Hi guys, Softube support just emailed me and said this is a confirmed issue with Studio One 3.3.2. They said if I want to try reverting back to S1 3.3.1 that it might fix the problem. I have not done that yet, I have to research how to revert to a previous version. |
Trechuck wrote I've been tinkering around with studio one to try + work this out , I felt sure it was working previously. what I have found , on 3.3.2 + using vst3 ( so all track auto functionality) is that if I start studio 1 and open project I am working on with console 1's inserted then they do not seem to appear. what I have discovered is that if I open a different song first and then close this .. and then open the project with console 1 inserts , as soon as I click on a channel with console 1 inserts everything working fine. so maybe this could be worth a try, open any other song first , close it , .. then open the song you want to work on with saved c1's. |
Trechuck wroteWell, I reverted to S1 3.3.1, and the Console 1 integration seems to work fine now. Settings saved between sessions, etc. ah cool, 3.3.1 still has console 1 full feature set. will probably roll this back myself. but does seem to work fine in 3.3.2 if you open any song then close before opening song you want to work on. makes u wonder what else might be wrong though + looking at release notes not missing a lot in 3.3.2 , just faderport 8. |
Trechuck wroteNew here, hi guys. I have an issue with the Console 1 to Studio One 3 integration. I filled out a support ticket with both Softube and Presonus, but since it is the weekend, thought I would try here in case someone knows how to solve: Same here. Deactivating and then reactivating all Console 1 instances seems to do the trick. Then all settings reappear. |
damblack wroteGammon2004 wroteAny idea if 3.3.3 fixes this behavior? I have been deliberately not using 3.3.2 since reading that it was causing issues with Console 1. (Thanks guys for posting about it!) I can confirm this. It's back again to 3.3.1.
Home Studio Connection
--------------------------------------------------------------------------------------------- Studio One 3.5 Pro - Win 10 X64 ( i7 6700k, 16 GB Dual 2400) - Focusrite 6i6 Focal Alpha 50 - Softube Console 1 - Faderport - Monitor Station v2 |
So, um....just to follow up, but it seems as though we're still at a place where we can't use Console 1 with the latest version of Studio One, and have been for about a month, correct? Really wondering when to expect a fix for this...
Gammon2004 wroteSo, um....just to follow up, but it seems as though we're still at a place where we can't use Console 1 with the latest version of Studio One, and have been for about a month, correct? Really wondering when to expect a fix for this... Whenever Softube fixes the problem. Absolutely ZERO chance Presonus will move a finger to make Studio One more compatible with anything. The same problem that some iLok-protected products had, until the original developers fixed the issue(s). |
I asked Softube about an estimated release time for the fix:
This is their respons: "We're doing our very best to release the fix for Studio One as soon as possible. It is definitely a top priority issue for us to fix. If all goes according to plan, the fix will be included in our next update. Our current software version is 2.3.90 (as seen here: https://www.softube.com/download.php). If there hasn't been a new version released in a couple of weeks from now, please get back to me and ask for an update."
Thanks for posting all of this info. I had been considering a Console 1 given its new price, but this thread reminds me that 3rd party controllers are at the mercy of third party updates. The Raven has the same issue from time to time.
Thx.
aka "gesslr" or "george napier" most other places online
12 core MacPro 5,1 2.66GHZ | 64 GB RAM | OSX 10.12.5 | LogicPro X 10.3.1 | StudioOnePro 3.5 | Cubase 9.2.0 | MOTU Interfaces | Way Too Many Plug-ins | http://www.soundwaremedia.com FB: geo.napier3 @gesslr via Twitter Vote for Studio One Workspaces! http://answers.presonus.com/11260/studioone-workspaces |
New update on Softube side arrived and works flawless with SO 3.3.3!!
The new bypass function in Console1 is also operational. Great!! The support of UAD is also implemented.
