Something weird is happening when I copy over a section of my midi notes to a new bar. Go to edit that bar and only that bar it also makes the exact same changes to the previous bars. How do I turn this option off? Drawing notes on one bar (the copied over bar) also gives them to the previous bar and all bars that are the same.
If you are using Ctrl + drag it will create a Shared Copy what you could do is use Alt instead, that way the edits you make to the original MIDI event won't affect the copy.
Another way to break the link is to right click on the Shared Copy ==>Instrument Parts and select Separate Shared Copies. Hope that helps. |
Users browsing this forum: No registered users and 55 guests
