Hello all: I wrote a short sweet little tune that has only piano (The Maverick) and some background violins/cellos (Spitfire Originals Intimate Strings), kind of like elevator music. It sounds a bit muddy to me since the audio spectrum is more or less the same for the piano notes and the stringed instruments, except for the very low cellos which don't overlap with the piano. This means that using ProEQ won't really help, or will it? I'm not an expert.
Does anyone have any suggestions or approach that they could recommend so that I can improve the quality of my final output? Any magical plugins out there? |
i use a plugin to cleanup bass/Kick drum interaction, vocals/lead instruments etc that works well for me. I'm pretty sure that you can demo it, see link below... https://www.pluginboutique.com/product/ ... rackspacer
Desktop
Windows 10 Pro ASUS X99 Deluxe MB 32G Ram i7 5820K 3.3 GHz ASUS R5 230 Series graphics MOTU 424 PCIe 2408 MK II Studio One Pro 6.01 Faderport 8 M-Audio Keystation 88 M-Audio Oxygen 8 Laptop Acer Nitro Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz 2.59 GHz 16.0 GB Ram SSD and M.2 drives SSL 2+ Audio interface Few Hammonds/Leslies Vintage keys (Rhodes 88, Solina strings, ARP Odyssey, Hohner D6, etc) |
I use piano and strings myself. Overall, I usually cut a little low end from the piano, depending on the plugin used. I also try to pan my stringed instruments according to where they actually sit in an orchestra. This helps to separate them. I keep the piano middle-ish. Depending on the tune I might put convolution reverb on the entire mix, to simulate music being played in a hall\theater, rather than on individual tracks.
Search for "orchestra seating arrangement" might help as guideline for your mix. Good luck |
