Share your songs!
Here's a new one.
Synth-scape stuff.
phpBB [audio]
by sebastianholtzer on Wed Feb 14, 2018 9:19 am
Real good Ideas and Sound Visions you had here. For my personally taste i prefer a bit more punch on the kick drum. Snare were fine and snappy.
by Bbd on Sun Feb 18, 2018 8:25 pm
So the parts and piece are very good.
The delivery (the mix) good use some help.
The low end is missing. If you monitored thru a system so that you could hear through speakers sounds from 35HZ to 90 HZ, you could listen to commercial songs for how they achieve an overall broad frequency range on their mixes.
Since you already have nailed the parts, you should consider in the mix, remove any low pass filters to let more of the 30-60 hz thru. Then, make sure you can easily feel and hear the kick and bass parts.
Then, you adjust the overall levels to harmonize.
I think a simple adjustment like this would help a lot.
OS: Win 10 x64 (16299.125), Studio One Pro 3.5, Sonar Plat Win 10 64, Steinberg Cubasis, Notion 6, Steinberg UR44, Purrrfect Audio Pro Studio DAW (Case: Silent Mid Tower, Power-Supply: 600w quiet, Haswell CPU: i7 4790k @ 4.4GHz (8 threads), RAM: 16GB DDR3/1600, OS drive: Samsung 850 EVO 500 GB Internal SSD SATA 6Gb/s 2.5" MZ-75E250, Audio drive: 1TB HD, Equator D5 monitors, Faderport 16, Akai MPK261, Roland T6, ATH-M50, 70's Custom Fender Strat, Ibanez Micro Bass, Epiphone Masterbilt DR-500MCE
by chrisprovine on Mon Feb 19, 2018 8:32 am
Hey, thanks for the input!
Yeah, low white whale.
I live in a small apartment and need to mix/play/compose though headphones all the time.
Great suggestions.
I need to spend more time with good, "like-sounding" reference tracks and experiment from there.
Users browsing this forum: zyklop and 3 guests
