Routers, Switches, Cabling, Access Points, Repeaters, etc all discussed here
SL24s3, NSB 16 and 8 (latest firmware). Second time using NSBs both times had AVB dropouts for approx. 1/2 second at various times on both inputs and outputs.
Use new pro audio cat6 cable with ethercon type connectors (100' and 20')
1st time in use was using cat5 cable had same problem, changed to new high quality cat6.
Clean AC power
Anyone else seen this AVB dropout singal problem?
SL24 s3
NSB 16.8
NSB 8.8
Dell Studio 1558 laptop, 6GB ram
Windows 7-64bit
Capture 2, iPad 2
by Trucky on Tue Feb 12, 2019 6:07 pm
You said you're using the latest version but please identify which versions are installed for the following:
Universal Control
Series III 24
NSB 16.8
NSB 8.8
How are these connected (please describe)?
Also what brand (include product ID/specs) of network cables are you using?
Windows 10 Pro 64-bit (v1809: Build 17763.253), Studio One 4.1.3 Pro | Notion 6.5 | Universal Control v2.10.0.50756
Dell Inspiron 17 5770 (Intel Core i7-8550U 1.8 GHz, 4GB AMD Radeon 530 Graphics, 16GB RAM, Samsung 850 EVO 1TB SSD
StudioLive Series III 32 v1.10.15552
by mgmarsh on Wed Feb 13, 2019 6:35 am
UC ver. - 2.10.1.50831
SL24 s3 - 1.10.15552
NSB 16 - 1.1.0.15533
NSB 8 - 1.1.0.15534
GLS Audio Pro series super cat6 digital network cable (1 - 100', 1- 20') - Have try other cables with same result
cable connection Mixer to NSB16
NBS16 t0 NSB8
SL24 s3
NSB 16.8
NSB 8.8
Windows 7-64bit
Capture 2, iPad 2
by ryanworsham on Fri Feb 15, 2019 8:52 pm
I had the exact same situation a couple nights ago and I too have the latest firmware and revisions. I have the SL32, sl32r and the nsb 16:8. So only 16 of my channels are going through the nsb but the drop outs were coming from the mains. I was doing some investigating and I realized my cat 5e/6 cables were iterally moving inside the port and causing a short. So basically, every time the subs hit, the cat 5e/6 cable from my rack mixer to my console would vibrate and I would have that brief pause as u described. Having said that, I have the locking cat 5e cables on order now so I'm hoping this fixes the problem.
SL32 iii
SL32r iii
NSB 16:8
SW5E
