Discuss using Dante, Audinate Software and Dante enabled consoles, etc.
1 post
Version 3.7.0.30 of Dante Virtual Soundcard for OS X is a major release which includes a new user interface, increased audio format support, support for OS X 10.9.5 and 10.10, and a range of other new features.
What's New:
User Interface redesign
Sample rate and audio format (bit depth) must now be set via Dante Controller
Channel count can now be set directly from the Settings screen
Support for 16-bit and 32-bit audio
Support for 44.1 kHz, 176.4 kHz and 192 kHz sample rates*
Support for sample rate pull-up / down
Latency stats, late packet stats and signal presence are now exposed to Dante Controller
Support for OS X 10.9.5 and 10.10
* Maximum performance at 176.4 kHz and 192 kHz requires a modern, dedicated computer, specifically tuned for processing high-quality audio.
Please see the online help for more information about new features.
Supported Platforms:
OS X 10.10
OS X 10.9.5
OS X 10.8.5
OS X 10.7.5
Version:
3.7.0.30
Release Date:
Thursday, December 18, 2014
Bug Fixes:
#697 / #4871: Sample rate changes would sometimes not successfully propagate to Nuendo.
#7063: Fixed a bug where OS X multicast Rx wouldn't work if a wireless interface was active.
#5826: Fixed the occurrence of random system hang after extended running.
#8396: Fixed a PTP timing issue after extended running on Mac Pros.
#7275: The DVS name would sometimes default to 'localhost'.
#7994: Fixed a bug that caused the DVS name would change after sleep / wake.
#8563: Dante Control and Monitoring would sometimes fail to reconnect after a reboot on OS X.
#8608: DVS would sometimes fail to restart after a reboot on OS X.
Known Issues:
#7034: In WDM mode on Windows 8, DVS sample rate changes are not automatically propagated to the system audio settings, and they must be changed manually. See the user manual for more information.
#8400: Under certain conditions, DVS and Dante Controller can display diferent device names for DVS. Workaround is to restart Dante Controller.
1 post
