I think an in ear system over cat5 cable. Like that of behringer system but where it can be controlled by AI or UC software.
If the dante card will give you direct outputs of the mixer channels you should be able to use a mac as a monitor station.
Just aggregate the builtin soundcard with a virtual dante soundcard and you can mix your monitor(s) with some 6mS latency or so...
SwitchBack wroteWow, 6ms is a lot. Only if you are a singer using iem's, but the price is right
SwitchBack wroteTrue, but it won't get any faster either. Add a plugin or two and it might start to get annoying. Hmmm, need to read up on AVB/Dante latency to find out if a fast computer would reduce those 6ms by half... Not with the virtual soundcard. It is cap'ed at 4+1mS as its lowest latency. The only way to get any lower latency is to use https://www.audinate.com/products/manuf ... -pcie-card Best thing is that it supports a thunderbolt to pci box for those laptops... Another option is to connect a x32-core with x-dante and have it convert the digital audio to the ultranet protocol and then use the p16 monitor system. A perfect symbiosis where presonus #heart# behringer
