This is really nice:
Users can also connect non-Dante mixers, such as a first-generation StudioLive, to the analog inputs of a Dante-equipped AI loudspeaker and then broadcast the signal over the Dante network using CAT5 cables. How many channels of audio would go to the dante network - Two?
I believe you're referring to the Dante VIA software that has not been released yet. That's a question only Audinate can answer at the moment and even that will depend on the combination of hardware and software used.
For example, if it is a hardware Dante card you'll get better latency according to their data and, if I recall correctly, greater throughput. If it is all software then it will be more limited. I'm sure combinations of both in different equipment will yield different results as well or be limited to the lower capable item. |
PreSonuSupt2 wroteI believe you're referring to the Dante VIA software that has not been released yet. That's a question only Audinate can answer at the moment and even that will depend on the combination of hardware and software used. No, this is not what I meant. That was a quote from your press release regarding the dante card on your studiolive speakers. According to that press release the speaker will translate analog input to dante. Since the speaker has two inputs I'm wondering if the dante card will output two channels as well.
The Dante card is a 2x2 card, so max 2 outputs.
