This is really nice:
Users can also connect non-Dante mixers, such as a first-generation StudioLive, to the analog inputs of a Dante-equipped AI loudspeaker and then broadcast the signal over the Dante network using CAT5 cables.
How many channels of audio would go to the dante network - Two?
Behringer Wing, iMac late 2015, Behringer X-Touch, X-Touch ONE, M-Air mr18, X-Air xr18, x32 with Dante/aes67, x32-rack with Dante/aes67, s16 and sd16 stageboxes, p16 monitor system, TurboSound iQ-speakers, Waves x-wsg with SoundGrid server, Motör 61, BCR-2000, StudioLive 24, FirePod 10, Apogee Ensemble, Alesis HD24, Studio One Pro v4, Notion 6, NI Komplete 11 Ultimate, Halion 6, Nuendo 10, Ableton Live 8 Suite, Reaper 4, misc Line6 gear/software, True Temperament Frets on basses and guitars, Korg Kronos, Roland vk-7, Behringer Deepmind 12, Behringer Neutron, Yamaha 02r.....
by PreSonuSupt2 on Fri Oct 17, 2014 8:07 am
I believe you're referring to the Dante VIA software that has not been released yet. That's a question only Audinate can answer at the moment and even that will depend on the combination of hardware and software used.
For example, if it is a hardware Dante card you'll get better latency according to their data and, if I recall correctly, greater throughput. If it is all software then it will be more limited. I'm sure combinations of both in different equipment will yield different results as well or be limited to the lower capable item.
by roblof on Fri Oct 17, 2014 8:14 am
PreSonuSupt2 wroteI believe you're referring to the Dante VIA software that has not been released yet. That's a question only Audinate can answer at the moment and even that will depend on the combination of hardware and software used.
No, this is not what I meant.
That was a quote from your press release regarding the dante card on your studiolive speakers. According to that press release the speaker will translate analog input to dante.
Since the speaker has two inputs I'm wondering if the dante card will output two channels as well.
by PreSonuSupt2 on Fri Oct 17, 2014 10:11 am
Ah, I misread. You are correct.
Analog into the speaker and Dante back out.
by mwright137 on Sat Oct 18, 2014 10:45 pm
The Dante card is a 2x2 card, so max 2 outputs.
Studio One 2 Pro 3.3.x (64 bit). MacBook Pro 13". OS X Sierra version 10.12.3.
RM16AI and CS18AI connected in Stagebox mode via MOTU AVB Switch.
StudioLive 328AI (x2); AudioBox 22 VSL; BlueTube DP V2; FaderPort; Monitor Station; RC 500; Temblor T10.
My Website
