Not sure if this is a Dante problem, a console problem, a computer problem or an operator problem. I've recently installed the SL-DANTE-MIX card in my 32.4.2 , in the expectation of using it to record the various outputs of the board (I'm trying to get away from Firewire for multitrack recording, among other things). I've loaded the Dante virtual soundcard and Dante controller on my computer (PC running Win 7 SP1), and everything appears to be talking back and forth as it should, however, no audio from the board - when I try to establish a cross-point in Dante Controller from any output on the 32.4.2 to any input for the computer, I get red circles with the note "No Audio". I can play tracks back through the board on the Dante connection (instant green checks whenever I make those routes), but that doesn't help me at the moment. I've tried recording on Studio 1 ver. 3, Audacity and Reaper, all with the same results. I've seen posts on these forums that state that other users have succeeded in getting the 32.4.2 to talk to Studio 1 via Dante, but no explicit description of how it was done. What have you been doing that I missed?
If you are using a wifi router it may affect your dante performance badly.
Studio One Pro v5, Notion 6, Nuendo 11, BitWig v3, Reaper v4, Ableton Live 8 Suite, iMac late 2015, Behringer Wing/x32-BigBoy/x32-rack all with Dante/aes67 and s16/sd16 stageboxes, Flow8, Waves x-wsg with SoundGrid server, Behringer X-Touch, X-Touch ONE, M-Air mr18, X-Air xr18, DP48, Hub4 and p16 monitor systems, TurboSound iQ-speakers, Motör 61, BCR-2000, FirePod 10, Apogee Ensemble, Alesis HD24, NI Komplete 12 Ultimate Collectors, Halion 6, True Temperament Frets on basses and guitars, Katana-100, DT-50, JSX, JCM800, Korg Kronos, Roland vk-7, Behringer Deepmind 12, Behringer Neutron
Try the linked article below. There are a few steps to be taken, and following these steps should correct, or help isolate the issue. If all else fails, open a support ticket.
http://support.presonus.com/hc/en-us/ar ... -Computer- |
Also, make sure that your switch isn't one of those energy saving devices. Most of them fail with dante.
I have had two older wifi routers fail on me, even though I only utilized the ethernet ports and not the wifi.
I am not certain if this answers your question but when I use Pro Tools to record over the Dante network, I need to make certain that the input for PT is the Dante Virtual Sound Card and not the Presonus SL2442AI.
Pro Tools will record (or work as an outboard EFX server which is what I use it for) on Dante. Wave Tracks Live will also see the Dante network. Capture 2 will not. Does this help? Doug |
Couple of other things to be aware of;
When you fit the Dante Mix card to the 32.4.2 (or any other PreSonus StudioLive AI mixer) make sure you run the latest firmware upgrade again even if your mixer is fully up to date. This should ensure that the Dante Mix card is fully patched to the current firmware also. You don't know what version of firmware the Dante Mix card shipped with nor how long it's been on the shelf. Secondly Dante have recently released a new version of Dante Controller v3.10 that amongst other things, quote; Wi-Fi Support The new Dante Controller 3.10 software allows users to manage Dante networks from laptops connected via Wi-Fi. By simply connecting a wireless access point to a Dante network, adjustments can be made from any location in a facility, unencumbered by cables. Not sure if the latter is applicable to you but is worth bearing in mind. Hope that helps? Kind regards, -=Glyn=-
PreSonus StudioLive 16.0.2 Firmware 0.98f Build 219
PreSonus StudioLive RM16AI Firmware 1.0.7784 MacBook Pro 2.3GHz i7/16GB/1TB SSD/El Capitan 10.11.6 MacBook Air 1.7GHz i7/8GB/512GB SSD/El Capitan 10.11.6 Universal Control 1.7.3 (1.6.5742 Driver 4.2.0.39752) Universal Control AI 1.5.0.36497 UC Surface 1.8 Studio One Professional 3.2.0.36707 Capture 2.2.0.36497 SL-Remote 1.5.5503 QMix 1.3.5508 QMix AI 1.2.29258 iPhone 6S iOS 9.3.4 iPad Air 2 iOS 9.3.4 |
I have the same problem...
I bought the SL Dante card because I should be able to record from my StudioLive24.4.2 directly to StudioOne on my Windows 8.1 computer instead of trying to find at computer with firewire. But I cant get it to "work" yet. In this link it states: http://www-media-presonus.netdna-ssl.co ... rking1.pdf "If you have only one Danteenabled device to connect to your computer, you can eliminate the switch and simply connect the two with a CAT5e or CAT6 Ethernet cable." The mixer is connected directly to the computers ethernet port and I have dowloaded both Dante Controller(v.3.10.0.19) and the Dante Virtual Soundcard(Purchased) - Also I have downloade the Dante Firmware update manager and loaded the StudioLive 24.4.2AI.dnt file The StudioLive24.4.2 firmware is: SL 1.0.9194 The UC version is: Universal Control v1.8.3 But I cant get it to work! No audio from the StudioLive24.4.2 to StudioOne... |
What does the dante controller tell you about your configuration and what about the logs?
ok, so you connected the 24ai direct to your computer with cat5/6..
Q1, does UC on the computer "see" the 24ai? Q2, is the cat5/6 the ONLY network connection on both the 24ai and the computer? Q3, have you started Dante VSC? Q4, Does Dante controller see both the 24ai and the computer? Q5, Have you set up routes in Dante controller matrix? (24ai transmitters -> computer receivers) Q6, Have you assigned Dante VSC as sound card in your DAW? "But I cant get it to work! No audio from the StudioLive24.4.2 to StudioOne... " So is any of it working? Which bit doesn't work?
Karyn
