Discuss using Dante, Audinate Software and Dante enabled consoles, etc.
Cisco 300 switch, properly configured. SL2442 with latest firmware. Have the SL2442 set to dynamic IP, using a Linksys router as the IP server. When I power cycle the board, Dante Controller shows the SL2442 as a device, shows gigabit speed all around, shows sync lock with SL2442 as master clock.
The SL2442 shows one IP and the Dante Controller has it as another. The board is otherwise unrecognized by the Controller and can't be assigned as either transmitting or receiving. What do I have mis-set?
D.
by tourtelot on Mon Jun 20, 2016 9:29 pm
I think I figured it out. I believe that the Dante Controller is seeing the IP address of the switch port, not the device. All seems good.
D.
