Can anybody tell me how to do a simple L/R recording (so from the main L/R bus, preferrably pre-fader) on Capture with the RM32 ? When I start Capture it displays channel 1 to 32 and a stereo Aux1/2 en Aux 3/4 but those aux channels are not L/R and they are kept silent... According to the docs, the last channels (33/34) should be assigned automatically to the L/R mix, but that doesn't seem to happen. Bug perhaps? Greets, Mark. |
markvroom wroteCan anybody tell me how to do a simple L/R recording (so from the main L/R bus, preferrably pre-fader) on Capture with the RM32 ? 1) Go to the settings page of the RM and select the Aux Routing tab. 2 a) Post-fade L/R recording in Capture on tracks 33/34: select the as Capture Master 33/34 the box that is aligned with Main L/R. 2 b) Pre-fade L/R recording in Capture on tracks 33/34: select the as Capture Master 33/34 the box that is aligned with e.g. Mix 11/12. Click Mix 11, link the mix busses 11+12, name it to something like "Rec", select Pre1 or Pre 2 depending if you want to record without or with the dynamics and EQ, set the levels. |
