Just hooked up my StudioLive 16.0.2 to my PC for the first time. I run Capture, I arm tracks 1 and 5. I record. Audio is being recorded on both tracks, meters are good, the tracks show audio.
When I play back, all I get is audio from track 1. If I move the recorded audio from track 5, up to track 1, it will play fine. So why won't it play on its original track (5)? |
You need to turn on the digital return for each channel if you want playback on the original channels. You need to tell the mixers if you are using an analog input (to record) or a digital input (to play back).
