Capture needs "reset" between sessions
Posted: Thu Nov 07, 2019 10:59 am
by stephanjerde
We have a 32RML, and I installed the July 8, 2019 build of Capture, the current version, I think.
I can record just fine, but when I shut down the system, on restart, it can no longer find the 32RML. I have to unplug the firewire from the back of the computer and plug it back in, click on retry,and then it can find it just fine.
Problem is the computer is also rack-mounted, and all the connections are on the back, so the disconnect/reconnect every time is inconvenient, to say the least.
I've tried starting the computer first, starting the 32 first, starting them both at the same time, all with the same results.
Any suggestions? Is there a setting somewhere I can't find?
Thanks!
--Steph
Re: Capture needs "reset" between sessions
Posted: Thu Dec 19, 2019 5:59 pm
by stephanjerde
Bought a new firewire card. Fixed the issue.
