Suggestion to make Capture more user friendly to .
Posted: Mon Feb 20, 2017 9:24 pm
I know a few small companies and individuals that use their StudioLive IA to record using capture because it is simple to use.
After laying all the tracks, It is easy enough to play all the recorded tracks back though the mixer to create a simple stereo mix that can be recorded as a stereo pair on tracks (17,18), (25. 26) and (33,34) depending on the model mixer you have.
What is needed is a simpler way of breaking out and saving that finished stereo recording from the rest of the stems. I am thinking about beginners or people that don't record for a living.
We should be able to go to FILE at the top of the screen and select -- publish final stereo recording (wording for this could be better) and pick where the new stereo file will be placed on the computer and if the file will be MP3 or some other audio file stile. Maybe even name the recording at that time. The important point is that the computer program be able to find the final recorded stereo pair on tracks (17,18), (25. 26) and (33,34) depending on the model mixer you have. And easily create a MP3 file or other audio file for sharing
The point is not everyone wants to mix in StudioOne , They just want to mix in Capture using the mixing board and create a simple stereo file that is easy to publish and share with friends.
