We normally gig with our Mac book and we record our gigs. We then mix down to tape from the board. At the studio we have a iMac hooked up in our practice room. How to we move capture projects from the Mac book to the iMac. We keep getting a files missing error?
You need the .capture file and the subdirectories in the directory where you found that file. In particular you need the directory with the .WAV files. When you open the .capture file on the iMac you can still get a missing file warning. If so then you can find the missing files in the subdirectories you copied together with the .capture file.
Note that copying the 'cache' directory is optional. If that directory and/or the files that were in it are not found then capture will re-create them. All you lose is a bit of time. |
