Hi guys, sorry if this has been covered already BUT....
I did a short live session with a friends band. Took out the macbook pro and external HD with 32RM. I recorded 12 tracks in capture. Between takes we'd have a listen to their performances to critique. It took me awhile to figure out that I needed to click the FIrewire or digital button in Capture to hear the playback. What I discovered after that was the track inputs all switched over to network or firewire randomly in the UC and I'd have to put them all back to analoge inputs. This confuses me. Also, sometimes (random) I'd have only 3 or 4 tracks available to listen to on playback. slightly OT, I tried to store a session with a particular performance and when I tried to open it, I foud a previous performance was saved instead. Is there a cache someplace where I might be able to recover the track I wanted to save? Thanks! |
I might suggest you make sure your working with the latest board drivers, UC and Capture. You didn't specify which mixer, so I cannot be sure exactly what versions. You should find these and the instructions in your "My Presonus" account. If you flashing an Ai console, make sure you use the latest version, and do a firmware recovery... this will wipe the board clean so make sure to back up any scenes you have first. The reason for the recovery method is, it makes sure there aren't any remnants of the old drivers in there to muck up the works... The stems should be in a folder (in PC it's in the documents under Presonus) in your documents, by default, but you can send them wherever you wish..
Tower:
Asus Crosshair V formula Z motherboard AMD FX9590 4.0 GHZ 8 CORE CPU 16GB 2400MHZ RAM CAS8 512 GB SSD PRIMARY HDD 1.5 TB THOSHIBA 128MB 7200 RPM DRIVE 2.0 TB WD BLACK 256 MB 7200 RPM DRIVE AMD R9-290 4GB VIDEO CARD Windows 7 P sp1 2006 Imac Lenovo thinkpad Z565 upgraded with a Quad core processor, SSD and maxed out 8GB ram Win7 Sp1 Mac 2006 Ipad 3, Ipad 4, Ipad Mini Iphone 6s+ Audiobox USB 1818VSL i2 Studiolive 2442Ai SL 16.4.2 X 2 Studio 1/3pro Sony Sound Forge 10 Engineer / producer Owner Twilite Zone productions Owner Studio G |
