I was just running sound over the weekend for a friend's band and decided to try out Capture for the first time. I was walking the room quite a bit and didn't get to spend much time over by my set up and I had the control surface window up with Capture running behind it, so I didn't see that I was getting a "Disk too slow, dropouts may have occurred" or something similar to that warning message. That warning popped up quite a few times, never stopped recording though. I just had a chance to check out the audio and most of it is fine, but there are portions of the audio where it gets digitally "distorted" and sounds robotic, or the audio actually speeds up and sounds robotic. I was recording about 16 tracks at 48k, 24-bit wave. Firewire out of the RM32 to a Firewire to Thunderbolt adapter into the MacBook. External hard drive is USB 3.0. Gear listed below.
I was in a hurry, so I missed increasing the Device Block Size, and it was at 512 samples. Would this maybe have been my issue, or do I need to find a better hard drive option for recording, or other? Thanks for any help/insight. MacBook Pro (Retina, Mid 2015) 2.5 GHz Intel Core i7 16 GB 1600 MHz DDR3 RAM OSX Yosemite Version 10.10.5 Seagate 5TB Expansion Desktop external drive USB 3.0 7200 RPM (Mac OS Extended (Journaled) format) StudioLive RM32AI Firmware v5651 Capture 2.1.1.31798
Go with a bigger block size. Something around 2048 or the highest setting will work. No need to worry about latency with a capture recording because they aren't performing to that.
A 7200 rpm should be fast enough, as should usb 3 on paper. Is this an external drive or internal. Id the external drive natively USB 3.0, or is it just a drive plugged into a USB 3.0 jack? Have you ruled out a potential bad cable? |
It is an external hard drive, and is natively USB 3.0. I haven't noticed any issues with the cable. The drive is fairly new and I've mainly been using it to store and work on video projects with Final Cut Pro. I've had no problem editing/transferring video off of it.
I had a feeling I was going to kick myself for not increasing the block size, I just wasn't thinking about it at the time and was in a huge rush as it was a completely last minute thought and I was trying to get it going before the band started. Won't happen again. |
I've had no problem editing/transferring video off of it. No really a factor. Realtime audio streaming is a totally different animal than video editing. I think the combo of a higher sample rate, and smallish block size worked against you here. |
