Hello,
i hope someone can help me. and sorry my english isn't good enough. I have the Problem, that the firewire- Connection between my imac AND as well with my macbook to the mixer get lost. The mixer-windows is closed and sometimes it's restarting again by itself. I also changed the firewire-cable. and it is since the update of yosemite v10.10.5 Has anyone the same Problem ? and the correct solution ? |
If you find yourself upgrading your OS, you will also need to make sure you have the latest board drivers. These are found in your account... please note that there should be a "revision notes" section with each software version that will tell you of any compatibility issues. So, in short update all your drivers and make sure your OS is up to date. One further note, when a new OS comes out, make SURE that your setup will work with it before you jump!
Tower:
Asus Crosshair V formula Z motherboard AMD FX9590 4.0 GHZ 8 CORE CPU 16GB 2400MHZ RAM CAS8 512 GB SSD PRIMARY HDD 1.5 TB THOSHIBA 128MB 7200 RPM DRIVE 2.0 TB WD BLACK 256 MB 7200 RPM DRIVE AMD R9-290 4GB VIDEO CARD Windows 7 P sp1 2006 Imac Lenovo thinkpad Z565 upgraded with a Quad core processor, SSD and maxed out 8GB ram Win7 Sp1 Mac 2006 Ipad 3, Ipad 4, Ipad Mini Iphone 6s+ Audiobox USB 1818VSL i2 Studiolive 2442Ai SL 16.4.2 X 2 Studio 1/3pro Sony Sound Forge 10 Engineer / producer Owner Twilite Zone productions Owner Studio G |
