I have an equipment rack with all my live gear installed. The Lightpipe is installed low down the rack, 6U below 3 Samson Airline UHF receivers. Two of these receivers pick up strong UHF interference and by switching equipment off one by one it appears that it is the Lightpipe that is the cause. Anybody any ideas how to stop this? or similar experience?
All help appreciated. Cheers from sunny France, Richard |
Quem estiver usando firestudio lightpipe com o Mavericks 10.9 e estiver com bugs,problemas de sinc, tentem fazer o mesmo o que eu fiz, deu certo...
( instalem todas as atualização de segurança para o 10.9 e comprem um cabo firewire original da apple [ firewire 9-6 pin cable da marca belkin], qem estiver usando porta t tunderbolt compra o adaptador tunderbolt firewire e o cabo firewire 9 to 6 pin da belkin. comigo deu certo e esta funcionando 100% sem problemas. antes existiam ruídos, travamentos, parava de funcionar não sincronizava com meu iMac, agora esta tudo certo...) |
tradução google...
Anyone using FireStudio lightpipe with the Mavericks and 10.9 is buggy, sync problems, try to do the same what I did, it worked ... (Install all security update for 10.9 and buy an original firewire cable apple [9-6 pin firewire cable of the brand Belkin], are using door qem t tunderbolt buy tunderbolt firewire adapter and FireWire cable 9 pin to 6 of belkin. worked with me and is working 100% smoothly. before existed noises, crashes, stopped working not synchronized with my iMac, now it's all right ...) |
