How can I send output directly to hardware outputs 3/4?
Posted: Thu Mar 09, 2017 5:01 pm
by Xibolba
I'm using Sonar Platinum connected to my FireStudio Tube and am puzzling over something I'm seeing while trying to reamp. Essentially I want to record something dry, solo it, send it out to a reamp box and into an amplifier, and record the result with a microphone.
I'm configured to use outputs 1/2 (main) to send to my monitors and send my output from sonar to hardware outputs 1/2. In sonar I see meter deflection on 1/2.
In the Presonus Universal Control (UC) mixer I'm seeing output on all outs (1/2, 3/4, 5/6, phones).
So, now the problem/question. I've got my reamp box connected to 3/4. In Sonar I route my solo-ed track to 3/4 and see deflection on those meters. I do NOT see any deflection in Universal control. Seems like I should, unless I misunderstand how UC is routing things.
Is it possible to send a specific track to a specific line out? If so, how?
Thanks in advance.
Re: How can I send output directly to hardware outputs 3/4?
Posted: Sat Mar 11, 2017 1:28 pm
by cristofechabot
Hrmn....In Studio One that would be no problem. I'm not familiar with Sonar's I/O options tho.
We do have some longtime Sonar users lurking about so, hopefully, one of those guys will chime in.
Posted: Fri May 19, 2017 12:30 am
by MarkusHassold
I agree with chistofechabot.
One thing you might have to consider is, that the routing of your channels only is inside the DAW-Mixer - but if 3-4 also menas to go out to 3-4 on the firestudio-Zube is up top your settings in the I/O-Settings of your DAW/Song. That is rather a Question for a Sonar-forum.
But maybe it will help to look up these basic settings first.
