I am wondering if the 510-FS001 Midi breakout cable that is sold buy presonus will work with my Firestudio Tube? The Breakout cable depicted in the manual only shows MIDI in/out the 510-FS001 also has SPDIF in/out as well.
by cristofe on Fri Aug 07, 2015 9:49 am
I can't say for certain but I would guess the pin-out for MIDI is the same on both cables....the newer cable probably just made use of the extra pins to carry SPDIF. I've seen this cable used by other manufacturers as well so it probably conforms to a standard.
cron
