Has any one tried, if the Firestudio Tube can work with OSX Mojave? The driver UC 1.7.6 is mentioned to work with the Firestudio Project in the compatibility statement. So the question is: if that driver works, will it make a difference, if it's the Tube?
Any experiences?
- Mac Mini 6.2, (2014), internal SSD+HD, 2,3 GHz Core i7 quad, 16 GB RAM, MacOS 10.14.6 Mojave with Presonus Firestudio Tube, Firestudio Project with Universal Control 1.7.6,
Presonus Faderport 8, Atom, Bluetube DP, HP 4, Bluemax.....
- iMac 27" 3,4 GHz Core i5 quad, 1TB Fusion-Drive, 40 GB RAM, MacOS 10.15.7 Catalina with Presonus Studio26C
External harddiscs (3.5" - 7200 rpm) USB 3.0
Presonus Studio One Pro 5.0.1
Celemony Melodyne Studio 5
Softube Console1 MK II (Console1 Version 2.4.99)
by MarkusHassold on Tue Nov 06, 2018 2:03 am
Just seen, that the download site for the firestudio tube has been updated - so Mojave seems to be supported.
by lancedixon on Tue Nov 06, 2018 4:01 am
by MarkusHassold » Tue Nov 06, 2018 2:03 am
Hello,
I'm having sync issues with a FireStudio Mobile => MBPro under 10.14.1
I am using a FW400 to FW800 to TB adapter. It worked fine in the studio one day, turned everything on next day and no sync - flashing alternating blue & red light.
Tests:
Connected old Firebox unit to iMac under 10.11 with direct FW400 connection = OK
Connected FS-Mobile same = OK
Tried old Firebox to MBPro = nothing
Tried FS-Mobile to MBPro with external power supply = no improvement.
Tech "ticket" waiting on reply - 1 week.
I've tried just about every version of U.C. available with all the usual deleting reinstalling rebooting time wasting - no improvement.
I have work waiting - if you have any pointers - thanks.
Ozfrog
by MarkusHassold on Thu Feb 14, 2019 9:04 am
Same Problem here - After updating to Mojave the Interfaces (Firestudio-Tube and Firestudio-Project daisy chained) worked, but seemed to have hiccups (one channel of a stereo-playback dimmed in and out). there still was UC 1.7.4 installed - 1.7.6 did not work well under high sierra - but 1.7.4 did perfectly).
With UC 1.7.6 under Mojave there first was no sync at all - even the Firestudio Project alone did not work. But that was a cable-issue.
Seems to be working quite fine. First recording showed, all channels give a decent signal - like I'm used to with my Firestudios.
