Is it possible to transpose in Progression 3? I see a few usuful options in the 'Tools' menu but can't seem to use them?
First select the notes you want to transpose, then go Tools>Transpose and set the parameters. The only reason I can think that it wouldn't work is if you don't first select some notes to transpose. I'm using Notion not Progression, but I think it works exactly the same way.
