I am creating an exercise that I'd like to simply duplicate but at different note values. For instance, change all the measures from quarter-notes to eighth-notes.
Is there an easy way to do this in Progression 3??? |
If you select all the notes in question and press the equals key = you can then assign a new time value to all the selected notes by using their respective keyboard shortcut. So to change all the notes from quarter to eighth, you would select them all, press = and then press E.
Bear in mind that this will also have an impact on the number of notes per measure unless you also change the time signature. |
