I have recorded myself playing a few chords. The notes came out correctly, but the tab notation created impossible chords with multiple notes being played on the same string. I had the recording setting set to 10 (strum). What gives? Also, when I looked in the manual, it states, "The fret numbers for all notes you see in the TAB staff will always be accurate," which really is quite laughable since it has been my experience that the tab notes are almost always different than the position it was played in.
Yes, it's that too bad there isn't a logic programmed into Progression to avoid that.
I use Notion to compose on the guitar and it behaves the same way. I also own Guitar Pro, and it never behaves that way. It has a logic in the coding that avoids more that one note played simultaneously on a string and a logic of fret distance to what a human hand can play. |
