CHORD SYMBOLS AS SHEET
Posted: Tue Jan 24, 2017 11:04 am
by tobiaslieblein
When creating chord symbols and position them in an empty sheet, it is not possible to push two chords within one measure.
It happened to do the job once, but not without the bar ending as wide as 5 bars. The following bars refuse to keep two chords, while the next chords are just erased. No editing possible without loosing chords.
There should be a way to use 2, 3 or even 4 chords in one measure. :!:
I tried to workaround by writing rhythm notes in the score, which is no prob unless you keep it one chord per measure. But if a chord needs to be played at the 4 of a bar, which is a dotted half note for the first chord, followed by a quarter note for the second one, it messes up everything again.
Besides this, it would be very common to integrate custom chords into the main library, as the library itself just has the very rudimentary fingerings anyway.
