Sounds Are Not Available.
Posted: Tue Aug 19, 2014 11:01 pm
by michaelkoch-schulte
New user. As soon as I open the program and choose a template I get "Sounds are not available" error. No voice sounds, guitar sounds etc.
Re: Sounds Are Not Available.
Posted: Wed Aug 20, 2014 9:48 am
This is what I get everytime I open a new project.
My sound card works. It is set to Windows Sound and I've also tried WSAPI.
My samples directory is : C:\Program Files\Progression 2\Support which was the default from the install.
My VST directory is populated with disabled effects from my Amplitube install and I've added one VSTi which is PianoOne.
Posted: Thu Aug 21, 2014 9:10 am
What fixes this problem, I found out all by myself, ahem, is downloading the second file available to you in your account. I did not realize this file was "required" when I bought the product, nor to I recall this being mentioned anywhere. Anyway, the file is called: "Progression 2 Bundled Sounds For Windows". Without installing this 1.4GB download the program doesn't do much soundwise at least.
Posted: Thu Aug 21, 2014 10:58 am
AND THEN....AND THEN....you NEED too go into your FILE | PREFERENCES | AUDIO | SAMPLES FOLDER and change this to:
C:\Program Files\Progression 2\Sounds\Bundled\
than and only then does the program work.
I would suggest to the developers that they install the Bundled Sounds FIRST so when the Progression 2 program installs it SEES that the sounds are already installed!! Just a thought. Now I can play with this nice program.
Posted: Mon Aug 25, 2014 10:52 pm
by Kiwicomposer
michaelkoch-schulte wroteAND THEN....AND THEN....you NEED too go into your FILE | PREFERENCES | AUDIO | SAMPLES FOLDER and change this to:
........<SNIPED FOR BREVITY>........
Try pointing just to here (One folder further back than you mentioned earlier)
And making sure that the sounds sub-folders are all in there (as the Bundled Sound Installer should place them by default)..
That way any download additional Sounds that you buy will also be seen.
Posted: Sun Nov 16, 2014 10:24 am
by RecL2R
Thanks for the thread.
Helped me get things going.
Posted: Sat Nov 22, 2014 10:28 am
by robertachatz
I am using Progression 3. I installed the software then the sound file. When I open a file for electric guitar Progression tells me that electric guitar sounds are not available. Checking for updates Progression tells me my sound files are up to date. Following the above instructions I go to preferences/audio and check for the sound file directory and Progression tells me it is program files/ progression 3/sounds but there is no such directory.
Posted: Sun Nov 23, 2014 9:14 am
by robertachatz
Found the problem. I ran the download instead of saving then running. Works great.
Posted: Sat Dec 13, 2014 9:52 am
by richardknowles
I have the same problem but I don't undertstand your solution - how do you "run the download"?
I've installed the soundbanks into the right folder, I've selected the folder as described above in Preferences->Audio, (both \Sounds\ and \Sounds\Bundled\, no difference) and I'm still getting the terse error "Piano (or whatever) Sounds are not available".
I must admit I'm not very impressed with this software so far. Very cold and unfriendly, a quick start tutorial would have been nice.
Posted: Tue Dec 23, 2014 11:22 am
by richardknowles
In case anyone has the same problem - each time I tried to fix the above I re-opened my basic project that I'd used as a scratchpad - and it seems that it was the project that was unable to play any sounds. In other words, after making the correct settings and then starting a new project, the sounds were back.
A bad start but hopefully I'll get used to the rest of it.
Posted: Sun Jan 11, 2015 6:34 pm
by dustinblatnik
Help! I am using a mac. Just downloaded Progression 3. Each time I open a file it tells me that "E. Guitar sounds are not available."
I've read the posts on here about this but cannot seem to figure this out. Could someone provide me with the step by step for resolving this on mac?
Dustin
Posted: Mon Jan 12, 2015 2:04 am
by dustinblatnik
Downloaded the SOUNDS file... and all works
Dustin
Posted: Fri Sep 09, 2016 8:31 am
by manoskar
Now we have 2016 and I have the same Problem.
The download of "Progression "and of" Progression bundled sounds i"s completed, but they don´t come together.
It´s really frustrating , 15minutes for paying and downloading
and then? Help
