Discuss Progression - tab, notation & songwriting for guitar, bass, keyboards and drums
New user. As soon as I open the program and choose a template I get "Sounds are not available" error. No voice sounds, guitar sounds etc.
by michaelkoch-schulte on Wed Aug 20, 2014 9:48 am
This is what I get everytime I open a new project.
My sound card works. It is set to Windows Sound and I've also tried WSAPI.
My samples directory is : C:\Program Files\Progression 2\Support which was the default from the install.
My VST directory is populated with disabled effects from my Amplitube install and I've added one VSTi which is PianoOne.
by michaelkoch-schulte on Thu Aug 21, 2014 9:10 am
What fixes this problem, I found out all by myself, ahem, is downloading the second file available to you in your account. I did not realize this file was "required" when I bought the product, nor to I recall this being mentioned anywhere. Anyway, the file is called: "Progression 2 Bundled Sounds For Windows". Without installing this 1.4GB download the program doesn't do much soundwise at least.
by michaelkoch-schulte on Thu Aug 21, 2014 10:58 am
AND THEN....AND THEN....you NEED too go into your FILE | PREFERENCES | AUDIO | SAMPLES FOLDER and change this to:
C:\Program Files\Progression 2\Sounds\Bundled\
than and only then does the program work.
I would suggest to the developers that they install the Bundled Sounds FIRST so when the Progression 2 program installs it SEES that the sounds are already installed!! Just a thought. Now I can play with this nice program.
by Kiwicomposer on Mon Aug 25, 2014 10:52 pm
michaelkoch-schulte wroteAND THEN....AND THEN....you NEED too go into your FILE | PREFERENCES | AUDIO | SAMPLES FOLDER and change this to:
........<SNIPED FOR BREVITY>........
Try pointing just to here (One folder further back than you mentioned earlier)
And making sure that the sounds sub-folders are all in there (as the Bundled Sound Installer should place them by default)..
That way any download additional Sounds that you buy will also be seen.
Steve Currington
Wellington, New Zealand
Presonus Audiobox1818vsl, Presonus Audiobox USB, Focusrite Liquid Saffire 56, Presonus Faderport, Presonus Monitor Station v2, M-Audio Axiom Pro 49 keyboard, KMI QuNeo & QuNexus, sundry other external FX hardware, mics, plugins & instruments.
Studio One v2.6.3, Sibelius v7.x, Notion v5.x, Progression v3.x, Melodyne Editor v2.1.2, Logic 9.x
iMac's & MacBookAir all running OSX Mavericks 10.9.5
by RecL2R on Sun Nov 16, 2014 10:24 am
Thanks for the thread.
Helped me get things going.
Win7 Pro 64bit SP1 / Intel Core i7-2600 3.4GHz /12 GB DDR3 / RME RayDat / ART TubeOpto8, Motu 8Pre & Line6 UX2 Interfaces / StudioOne Pro v3.2.3 / SawStudio v5.5 SAC v3.1
by robertachatz on Sat Nov 22, 2014 10:28 am
I am using Progression 3. I installed the software then the sound file. When I open a file for electric guitar Progression tells me that electric guitar sounds are not available. Checking for updates Progression tells me my sound files are up to date. Following the above instructions I go to preferences/audio and check for the sound file directory and Progression tells me it is program files/ progression 3/sounds but there is no such directory.
by robertachatz on Sun Nov 23, 2014 9:14 am
Found the problem. I ran the download instead of saving then running. Works great.
by richardknowles on Sat Dec 13, 2014 9:52 am
I have the same problem but I don't undertstand your solution - how do you "run the download"?
I've installed the soundbanks into the right folder, I've selected the folder as described above in Preferences->Audio, (both \Sounds\ and \Sounds\Bundled\, no difference) and I'm still getting the terse error "Piano (or whatever) Sounds are not available".
I must admit I'm not very impressed with this software so far. Very cold and unfriendly, a quick start tutorial would have been nice.
by richardknowles on Tue Dec 23, 2014 11:22 am
In case anyone has the same problem - each time I tried to fix the above I re-opened my basic project that I'd used as a scratchpad - and it seems that it was the project that was unable to play any sounds. In other words, after making the correct settings and then starting a new project, the sounds were back.
A bad start but hopefully I'll get used to the rest of it.
by dustinblatnik on Sun Jan 11, 2015 6:34 pm
Help! I am using a mac. Just downloaded Progression 3. Each time I open a file it tells me that "E. Guitar sounds are not available."
I've read the posts on here about this but cannot seem to figure this out. Could someone provide me with the step by step for resolving this on mac?
Dustin
by dustinblatnik on Mon Jan 12, 2015 2:04 am
Downloaded the SOUNDS file... and all works :)
Dustin
by manoskar on Fri Sep 09, 2016 8:31 am
Now we have 2016 and I have the same Problem.
The download of "Progression "and of" Progression bundled sounds i"s completed, but they don´t come together.
It´s really frustrating , 15minutes for paying and downloading
and then? Help
