Has anyone here had a successful experience running Progression 3 on the same PC as Abelton Live 9.5 (I use Live with Push for it's sketchpad capabilities ... but also run Studio One 3; obviously not concurrently)
I'm not talking about running both programs at the same time, just that the two are installed on the same PC. I had to reinstall Live; but a bit hesitant about re-installing Progression ... any insight appreciated |
Ok .. home from work and I've tried the following ..
I uninstalled Live & Progression - cleaned registry of all reference to Live Installed Live on it's own - fine and dandy. Installed Progression - then run Live and it crashes. Creates what looks like an encrypted crash report that I've sent to Ableton support. I uninstalled Live & Progression & cleaned registry again - going to swap the install order this time. Re-installed Progression - rebooted. Re-installed Live .. run Live and it promptly crashes. Uninstalled everything ... then reinstalled Live .. no crash. Conclusion is that Live and Progression don't play nice together. I really like Progression, however it looks like I'm going to have to use it on a separate PC if I want to keep using it ... not going to happen in my current financial state ... and a bit pissed that this has happened. Looks like Progression support doesn't frequent the forums so will try to contact them directly (note I'm also contacting Ableton support) ... I really want to be able to use both productively. |
Not 100% sure it is related but: I have Live and Studio One and Progression installed on my primary DAW. I also have NI Maschine. Maschine was locking up consistently after I updated it to version 2.4.
I was told that both Progression and Notion had a problem with ReWire and they would need to be uninstalled. Instead I disabled the ReWire service in StudioOne. Problem was solved...but I can't use the ReWire service. I can however use Live, Progression and Studio One. HTH Michael Morgan | pearl hour project --------------------------------------------------------------- Intel i7-2600 @ 3.4GHz | 16G ram Windows 10 | Studio One v3.3.1 | Live 9.6 (all software 64 bit) RME Fireface UFX | Nektar Panorama P1 | AKAI MPK25 | M-Audio Keystation 88 I Maschine 2 | Fader Port 8 |
