Folder organization for scores
Posted: Thu Nov 05, 2015 12:13 pm
by davidborden
It would be great to be able to organize scores into a hierarchical folder structure.
I tend to compose a piece with many drafts, and work on different sections of a piece in a separate score document. It is difficult to manage and sift through dozens or hundreds of score documents in a flat single-folder structure the way that Notion iPAD is currently organized.
Currently to manage my scores, I have to save them off to DropBox and then re-import them when I want to work on them, in order to keep the number of visible scores in the App down to a manageable number. This leads to the problem of needing to double-check that they are saved properly, and then not being able to access all of them if I am working off-line.
Thanks for your consideration.
David Borden
Re: Folder organization for scores
Posted: Mon Dec 14, 2015 4:27 am
by chrisjobse
I see the same issue.
I want to keep my scores in several folders, depending on the projects I am working on. I can do that, but then I see them all in one long list. Additional to that is that I cannot open the scores residing in the subfolders.
Regards,
Chris
