Transpose by a semitone
Posted: Fri Jan 18, 2019 4:18 am
by kentimms
How can I transpose up or down by a semitone. Say from C to C#
Re: Transpose by a semitone
Posted: Fri Jan 18, 2019 4:58 am
by SwitchBack
Transposing is in 12 steps for a full octave, so +1 should take you a semitone up :)
Posted: Fri Jan 18, 2019 3:39 pm
by kentimms
Thanks
But where do I find the plus 1. There is Unison, 2nd, 3rd, 4th, 5th, 6th, 7th, and octave. The steps in the major scale. When the the switch is on chromatic I would have expected twelve semitone steps. When I started experimenting with this the change key switch greyed out so I couldn’t use it. After a while song stopped and landed me on the introductory screen. The only way around this was to delete the song and go back to my saved original.
I was able to go up by one semitone by going up by a 4th and down by a 3rd because there is one semitone difference.
Posted: Mon Jan 21, 2019 4:01 am
by lennyhodge
Transposing is in 12 steps for a full octave.
run 3
Posted: Thu Jan 24, 2019 6:38 pm
by kentimms
Ok but where is the +1. I can select octave but can’t see a+1.
Posted: Sat Jan 26, 2019 12:40 pm
by christopherrussell
You have to transpose both an octave and select an octave.
See image.
Posted: Sun Jan 27, 2019 7:49 pm
by kentimms
No that sends it up by an octave. Shouldn’t setting on chromatic give twelve steps?
Posted: Sun Feb 03, 2019 2:37 pm
If you want to transpose down, you make sure the down button is selected.
Posted: Fri Apr 05, 2019 8:31 pm
by alicetaylor
The article you have shared here very awesome. I really like and appreciated your work. I read deeply your article, the points you have mentioned in this article are useful
basketball legends
Posted: Mon Apr 08, 2019 8:25 am
by jabraham
kentimms wroteThanks
A minor 2nd is a semitone. So choose 2nd and also minor.
Posted: Sun May 26, 2019 10:43 pm
by phamyen
Thank you for such a sweet tutorial - all this time later, I've found it and love the end result. I appreciate the time you spent sharing your skills.
return man 3
Posted: Fri Jul 05, 2019 2:47 am
by heenacruzl
If we'd like to play that tune a semitone higher (in C-sharp or C#) we'll be using all black keys and two whites (f and c). Using the table above just use the note immedialety below the original, so a c becomes a c#, d becomes a d# an e becomes an f (or the enharmonic equivalent e#).
run 3
Posted: Tue Jul 09, 2019 4:10 am
by jerrydiwoodz
Thank you for the tutorial, im new with all this.
I appreciate the time sharing skills.
Regards! :punk:
