Hi All - I play saxophone in a cover band so I use Cubasis to import the original song wav file, then I mimic the sax line with a virtual instrument and create the midi file. My most common use for Notion is to open that midi file created in Cubasis and use the resulting Notion file as my sheet music score.
Many times the sax part doesn't come in until say, 8 bars after the start of the song. Can Notion show those 8 bars of rests as a single bar with "8" under the whole note rest, instead of 8 bars, each with a single whole note rest? Thanks! |
The Answer is YES
Look at the setting "cog" at the bottom of the screen and select either iPad View Settings (or the Parts Settings for dynamic parts ). On each there is a More button .. On that is the Muti-bar test setting.. I think, from memory, the number in there is the consecutive number of bar rests to show as individual bars before converting to a MultiBar rest. So for example if you set the number to 6 It will show 5 individual bars but as soon at it has 6 it will convert them too a Multibar rest. I suggest you test it and see. Here is an iPad screenshot
Steve Currington
Wellington, New Zealand Presonus Audiobox1818vsl, Presonus Audiobox USB, Focusrite Liquid Saffire 56, Presonus Faderport, Presonus Monitor Station v2, M-Audio Axiom Pro 49 keyboard, KMI QuNeo & QuNexus, sundry other external FX hardware, mics, plugins & instruments. Studio One v2.6.3, Sibelius v7.x, Notion v5.x, Progression v3.x, Melodyne Editor v2.1.2, Logic 9.x iMac's & MacBookAir all running OSX Mavericks 10.9.5 To add your software and hardware specs to your signature to make it easier for us to help you, click HERE. |
Forgot to mention the same is available on the desktop version too.
On the desktop it is under the Score Menu. See below for the desktop version
Steve Currington
Hi Steve - thanks for pointing that out! Unfortunately my file is not responding to any of the multibar rest settings. I've tried a second midi file to test - no luck on that one either.
Experiment and If it is not working then log a Tech Support ticket so that the tech support team can assist.
Steve Currington
OK, here's what I have come up with:
First, your score has to have AT LEAST two instruments. Go to the Gear>View...>Dynamic Parts... and select the part you want. Next, Gear>Parts Setting>More tab On this tab, in Multi-measure rests, select 2, and OK. This will put a MMR anywhere you have at least two empty measures. Actually, you're supposed to use the number equal to or just less than the spots where you want the rest, but if you just have one long one, it doesn't really matter. Note that this will only show in the part, not in the full score. Hope this helps! |
That second staff isn't a workaround; it's specified in the Help files. Just add another, empty staff to your score. When you specify the part for your lead sheet, it doesn't show. This might also work if you add a staff to your score, and hide it, there.
