Hi, I hope someone can help.
I'm having some trouble notating music in notion for iPad. It's all been going fine until bar 42 where I can't get it to input a dotted crotchet middle c. It keeps recognising it as an octave below. When I force it to be a middle c using the keyboard input and not the Apple pencil, once I write a subsequent note it drops the previous one an octave and then each subsequent note I write it drops the previous ones down yet another octave but only in that bar. Any ideas? I've tried deleting the bar and generating a new one but that doesn't work. I play the flute so I don't have anything below middle c |
Hi - this does sound strange.
Is this occurring just in one particular score or on all scores? Two possible workrounds to try: 1. Let it put the notes in and then transpose the notes up an octave. 2. Insert a new bar earlier in the score and then cut and paste to the proper location (then delete earlier new bar.) Otherwise open a support ticket with PreSonus by tapping the "Feedback" button on the bottom left of the home screen. Their responses are usually quite prompt. |
It's the first time I've encountered it and it only appears to be that bar and all subsequent ones I write. Although I've pretty much given up as everything I write, notion seems intent on trying to think for me. This would be fine if it didn't completely balls it up.
I'll give the second a go. The problem with the first is that it's compounding the octave drops so not all the notes need transposing by the same number of octaves. Failing that I'll try the help desk Thanks ! |
