Hey guys, I made a Custom Rule set for the VSL String Ensemble (Kontakt 5 Factory Library) that I thought I'd share.
Initially I had problems with getting it to work correctly but I finally got it right. Apparently I had to experiment a few times and discovered that the Pizzicato had to be on the very top of the rule set.
Open up the file in the Custom Rule GUI to see what I have done and the technique/articulation markings needed to make the key switches work.
To Kontakt 5 Factory Library owners, please test this out and let me know if it's working correctly. Enjoy! :D
K5 VSL Strings Ensemble.prules
(1.73 KiB) Downloaded 561 times
Mac mini (Server, late 2012) 2.3 Ghz Intel Core i7 with 16 GB RAM, (2011) Macbook Pro 15" 2.3 Ghz Intel Core i7 with 16 GB RAM, Mac OS X Yosemite 10.10.4 & 10.10.3, Notion 5.1, Sibelius 7.5.1, Logic 10.1.1
by Paulo Becker on Tue Aug 04, 2015 5:42 am
I could not make it work.
The Notion 's Guide does not provide any information.
This obscure, a tutorial facility would be needed.
The manual is horrible .
by ansontoh on Mon Aug 10, 2015 5:27 am
Mostly working for me, just that occasionally the notes might move to Pizz for no reason even if nothing has been assigned to it...
by georgesgondard1 on Mon Apr 10, 2017 12:35 am
for Contrabasses ensembles ;)
K5 VSL CB Strings Ensemble.prules
(1.93 KiB) Downloaded 358 times
