Here is a set of Custom Rules for VSL Special Edition presets. I am placing them on here so that you can work with them and test them out as you see fit.
For the .xml users out there from the past, look into the formatting of the Ruleset document. You will notice that there is no plugin id or group id. Rather the header and end tag for the documents are: <ruleset> Rules </ruleset> If you want to convert old files, that is the formatting that you should use before performing the import. Rules are now attached to your scores automatically and you can move them around from score to score. No more "Rules" folders. Just file your rules together and label them so that you know what they are for and where they are from and you are on your way. -Admin |
Josh,
Where is the «set of Custom Rules for VSL Special Edition presets» ? Do I understand ? Alain PS.... ...do you have a «How to build Rules for Dummies» document for user like me ? |
How are these rules different than the ones that ship with Notion? And, can you say something about the section of dynamic rules that are commented out?
Thanks! |
Hmmm...
Bill ask a good question ! There is no answer after more than a month ? So, I'm interested by an answer too ! ... |
