I'm trying to create my own ruleset for VSL cube.
I choosed to work with Vienna Ensemble (externaly loaded) which will contain all the orchestra instruments (because Notion crashs too often when loading high number of VST). Then in Notion, I create external midi instruments (violins, cellos, etc.), sending to Vienna Ensemble with LoopMidi (four ports of 16 channels).
The beginning of the rules creations started well, but I can't find how to create Midi Techniques (pizz, etc.).
I understand that one can make presets for instruments, but as I'm working with External midi I don't know how to do that (there is no instrument in Notion in this case, only midi...) ?
Is someone know how to do this ?
Thanksfully,
Terry
by Karmasutra69 on Wed Apr 29, 2020 10:32 am
Hi again,
I found how to have new techniques with presets files. I've created a preset XML, and an instrument file with new personnal techniques. However, in the instrument file, I didn't use a VST instrument but an external midi.
The instrument file works fine.
But if I recall the VST preset in a new Notion score, if everything seems fine (new techniques, layout, etc.), there is no external midi anymore. So this is not working for me and I really wonder why...
Can anyone help me ?
Thanks
Terry
by michaelmyers1 on Wed Apr 29, 2020 9:12 pm
I'm not sure why you are using the external midi send. You can send directly to Vienna Ensemble as a Notion instrument. You just have to create a separate staff for it. See my tutorial here (it's a bit old but still applies for the most part):
Let me know if you have any questions!
macOS Catalina 10.15 with small AOC monitor for additional display
JBL LSR310S subwoofer
Notion 6 + Studio One 5 Pro
http://www.tensivity.com
by Karmasutra69 on Wed Apr 29, 2020 11:34 pm
Hi, and thanks a lot for your answer.
I looked carefully at your tutorials and yes, it's working now, thanks a lot ! :)
However, I discovered that the parts names change after the instrument change. So except for the first page, I lose all parts names afterwards (it's written VSL Ensemble everywhere...very confusing when composing).
Is it possible to correct this behaviour ?
Thanks a lot again !
by Karmasutra69 on Wed Apr 29, 2020 11:43 pm
Ah, found ! All I have to do is simply rename the label of the Instrument Change by double clicking on it !
Hurray !!
:lol:
by michaelmyers1 on Thu Apr 30, 2020 6:06 pm
Karmasutra69 wroteThanks a lot again !
Happy to help! :thumbup:
