Is there a way to write a rule for a grace note? I'd like to be able to extend it a bit longer so it overlaps with the next one (that's what my VSTi wants), but can't find how to do that.
I haven't tested, but it could be as easy as:
Good luck |
I don't "write" my rulesets using code, I use the ruleset editor. Unfortunately there's no way to select grace notes as either a note type, a technique or an articulation that I can see in the editor.
However, I think there may be a workaround. I typically increase the duration of slurred notes using a rule that recognizes notes under a slur. This makes it work with legato patches in my VI's. Since grace notes in my experience are always under slurs, this could work to do what you want. Here's a rule in the editor for doing this: Hope this helps!
macOS Big Sur 11.1 with small AOC monitor for additional display 2 - 500 gb + 1 tb external SSD for sample libraries M Audio AirHub audio interface Nektar Panorama P1 control surface Nektar Impact 49-key MIDI keyboard Focal CMS40 near-field monitors JBL LSR310S subwoofer Notion 6 + Studio One 5 Pro http://www.tensivity.com |
I'm stuck in limbo between importing my old rules and using the editor. There are many inconsistencies, missing 'grac', e.g., as well as others that appear as techniques (qkud=Quick Up and Down) but then get translated as 'Circle' because the editor doesn't recognize the imported value--probably worthy of a support case.
Sorry it took me a while to get back to this.
davidsantamauro wroteI haven't tested, but it could be as easy as: I tried this, but I don't think it's working. Maybe I'm doing something wrong? Can someone confirm that "grac" works? I'm using Notion 6.5.470, 64-bit (Mac). Also, like you said, it gets translated to "Circle symbol" in the editor. |
