I'm working on a custom ruleset for Scarbee MM-Bass. Made some progress, but I'm a bit stuck with string selection. Here's one of my rules (for natural harmonics):
The flag I've set before, it checks if the note head is a diamond. MM-Bass expect an octave less than Notion's pitch, so I'm setting fixed-pitch to E3. And the key switch selects the A string in MM-Bass. The problem is the string condition, doesn't seem to trigger. I've also tried with:
But also no joy. On the staff, I've tried both entering the string with the symbol from the palette (number in a circle) as well as using the fretboard entry to choose the right string, and nothing has worked so far. Any ideas what I'm doing wrong? |
Solved. Actually there was no problem with the condition for string selection, I was just sending the wrong pitches (octave problems). Should have had a bit more patience before asking...
Just for the record, things like this work just fine:
