Dear Notion Team and Notion Users,
I have some harp libraries and I want them to behave like the VSL Harp for the glissandi : with the VSL Harp (with the Notion Factory presets), when I want the harp to do a glissandi in a particular scale, I just have to set the harp tuning (with the shortcut shift + H) and write a glissandi on the score (shortcut : shift + G) and the harp automatically plays the glissandi with the correct note changes. With my custom libraries (in Kontakt), when I write a glissandi, it playback a chromatic scale whether or not I set the Harp tuning. So it doesn’t behave properly for me at the moment. How can I set the same feature as the VSL harp for my own libraries ? Maybe by writing a specific custom rule ? Any help would be gratefully appreciated, it will help me integrate different libraries for this amazing Notion software and share it to the Notion Community ! Sincerely, Matthieu Dulong
Presets created for Notion :
Cinematic Studio Strings & Solo Strings - - - - - - - - - - - - - - - - - - - - - - - - - - - - Examples of music created in Notion with my custom presets Controlling multiple MIDI CC inside Notion |
The harp tuning diagram seems to work only with the Notion harp - strange - but my work-around has been to use the Notion harp preset, add all the techniques I need, including tuning diagrams, and then switch the instrument in the staff to the VST preset I want (in my case, VSL). The tuning "sticks" and will then still work with glissandi, etc. but with the preferred sound.
Thank you for your answer !
That seems to be a good workaround indeed ! I tried it by writing some notes and glissandi with different harp tunings with the Notion Harp preset and then switched to my Kontakt Instrument (using shift+I on the Notion Harp part to change the sound), but unfortunately it didn’t apply the right tunings. Am I doing something wrong ? I tried to follow your « trick » but maybe I didn’t understood it well ! Thank you again for your input on this subject ! Matthieu Dulong
Sorry for the delay in responding -
I don't change instruments using Shift+I, but rather once the harp part is all written out with the Notion Instruments harp, I click on Score Setup (top right of the control bar, next to the mixer icon) to open the score setup screen. Then I click the gear icon on the harp part and select the harp sound from whatever other VST I have loaded (in my case, VSL or Garritan). So, in effect you're "tricking" Notion into thinking it's playing the Notion harp, while playing the sound from a different library. |
