24 postsPage 2 of 2
1, 2
Matthieu-
I Have Kontakt 6. The presets don't seem to work with this....
am I missing something?
thx,
great work...
by alonshai-kaspi on Wed Apr 29, 2020 8:38 am
Hi Mattheu and thanks again for your great work in integrating CSSS with Notion 6.
Please forgive me if this has been asked before.
I downloaded The Zip folder and Placed Cinematic Strings in the Presets folder of Notion as you specified. I am not sure what to do next As my Cinematic Strings sounds are obviously in a different location and somehow they have to be played through Kontakt sampler that presumably needs to be launched.
As you may guess I need a little help in understanding the setup...
Can you please explain to me what needs to be done or corrected...
Thank you again,
by markcameron1 on Tue Nov 23, 2021 3:56 pm
Hi All ! I know this is older post but it's a goodie ! I have downloaded Matthieu's presets for Cinematic strings and am looking forward to implementing them into my Notion workflow. Thank you Matthieu !
I have a problem as I cannot get any sounds to play. The presets show up in Notion. Cinematic studio solo strings plays in Kontakt 5, if I use a vst instrument line for Kontakt , but it will not play sound via the preset.
I probably have the Cinematic studio solo strings library in the wrong place as I get this error message....
Cannot find the plug-in with ID 1315524405; make sure it is installed and enabled in the plug-in manager.
Violin Solo I sounds are not available.
If anyone has a suggestion on how to fix this I would be grateful.
Thanks in advance Mark Cameron
by markcameron1 on Mon Dec 13, 2021 11:55 am
In case anyone is interested I found the solution to my problem here.
viewtopic.php?f=169&t=34579&p=229221&hilit=csss#p229221
Thanks again to Matthieu for creating the preset it works and sounds great.
cheers , Mark
24 postsPage 2 of 2
1, 2
