Hello.
I have written a score in which I use 3 horns. Horns 1 & 2 are on the same staff and the staff has a G key. Horn 3 is written on a separate staff but with a key of F. When I play the score, there is no problem, all the horns sound at the correct pitch. In Notion; if I choose the display "score transposed", the horn 3 is 1 octave to hight. I do not understand why. When I print the parts to PDF, horns 1 & 2 are OK but the display for horn 3 is wrong. Horn 3 is displayed on a staff with a F key as I wanted, but is transposed 1 octave up. This is very Strange and I do not understand why. I have attached here a link to the .notion file and the .pdf file of the score. http://musicalis.monespace.net/dummy/ Can somebody help please. |
I assume we're talking about the G (treble) Clef, and F (bass) Clef here. It's common practice (but not generally correct) when writing for four horns to put them on a double (Grand) staff, with Horns 1&2 in the Treble Clef and Horns 3&4 in the Bass Clef. Properly, they should all be in the Treble Clef.
The range of the instrument spans both clefs, so horn players are used to reading either clef, but the normal rule is to notate the instrument in the Treble Clef. The horn is a transposing instrument, so it sounds a fifth lower than its written part. |
