Here is a rule set for the keyswitches of the Spitfire Sable Ensemble Patch running inside of Kontakt. Everything works as expected except con sord, which requires the "with mute" command (con sord doesn't work for me), and the trills are a little funky with the basic trill ('tr) being assigned to whole step trills and X1 being assigned to half step trills. (If someone could explain how to fix these anomalies, I'd be obliged.) The hairpin controller is assigned to CC1 but has not been refined. This rule set runs on midi channel 1. I set the Ensemble patch up on two or three staffs and use it for sketching.
