Is it possible to use a text string to tell N3 (three, not a typo) to switch to a different patch,
something like «If text = "a due" then jump to channel 2»?
Fabio Biolcati
Notion5
VSL SE 1 & 1+; 2 & 3 SE Strings
GPO4
2.4 GHz Intel Core Duo iMac
4GB RAM
10.11.4 El Capitan OSX
by johnnewberry on Thu Jan 14, 2016 12:14 pm
Hello Fabio.
"Text" added to a Notion score are not part of the Notion "technique" syntax, which is used to gain control of 3rd party VSTI's response with Notion.
Words, text and lyrics objects cannot be used to control instruments or playback performance in Notion.
,Newberry
:arrow:
by fabiobiolcati1 on Fri Jan 15, 2016 8:25 am
Thank you for your reply, johnnewberry.
Workarounds?
Any hint?
Fabio Biolcati
Notion5
GPO4
4GB RAM
by alexanderkissel on Tue May 10, 2016 9:07 am
Actually you can create a custom VST technique which you will be able to assign to a bar, it will show up as an additional technique in your pallet in notion. You will then be able to create a rule for this technique and get Notion to send Midi to different channel. So to sum up, its quite possible to do what you want to do.
by waynerose1 on Mon Feb 26, 2018 1:11 am
Sorry for tagging on to an old post.
But how does one go about creating a custom VST technique that will show up in the Notion pallet?
This may solve a prules problem I'm experiencing with Kontakt 5.
Help appreciated. Thanks.
Mac Pro 2.8 GHz 8-core (2008) 18 GB
Pro Tools, Studio One, Reaper, Melodyne
Sibelius, Notion
Focusrite LS56, Yamaha 01V96,
Neyrinck V-Touch, Studio One Remote, Lemur
