It is important to being able to hide the resting staves only after de first page as well.
I disagree. If you must have this page display for printout, then print page 1 separately, change the Score Setup, and print the rest of the file with rest with resting staves hidden. The inconvenience is minor, and, in my opinion, the request is beyond the scope of the application. If you want total control over printout (but poor playback), use Finale or Sibelius.
Best, Thorrild |
thorrild wroteI disagree. If you must have this page display for printout, then print page 1 separately, change the Score Setup, and print the rest of the file with rest with resting staves hidden. The inconvenience is minor, and, in my opinion, the request is beyond the scope of the application. If you want total control over printout (but poor playback), use Finale or Sibelius. That's a straw man argument if I've ever heard one. There's no reason Notion couldn't offer more printing/view options without adversely effecting playback. The playback part of Notion is extremely comprehensive in its current state, though not perfect. The next logical thing to do to improve Notion is to upgrade the weaker aspects. Printing, layout, appearance, etc. are obvious areas to build upon. If Notion can do that, there's no reason they couldn't better Finale or Sibelius on all fronts. In fact, that should be the goal.
AMD Ryzen 3950X, ASUS Creator x570 Mobo, 32GB HyperX Predator RAM (3600mhz), Radeon™ RX 5500 XT 4GB GDDR6 graphics card, RME Fireface 800, Windows 10 Pro, Studio One 5, Reaper 6, Cubase 10.5, Avid Artist Mix (EuCon please), Behringer X-Touch One, MIDI Fighter Twister, various other MIDI control surfaces and hardware instruments
Here is one example: In the attached PDF files, page 1 is printed separately with the "Hide Resting Staves" feature turned off. In the second PDF file you can see the following 4 pages (2-5) with the feature turned on. That's all there is to it.
Best, Thorrild |
Hi Thorrild, thank you about your reply. Anyway it doesn't work for me for a couple of reasons... Some I already know, I've sent a file to Brian and he just wrote me: "The problem is that you were using the "Hide resting staves" function. Unfortunately, if the first instrument in the score is hidden, it creates a problem with measure numbers and tempo markings. We hope to one day have this feature improved. Thanks for all of your patience. Best Regards, Brian Meisner."
So... If you have a work around please let me know. |
