It would be nice to have a rule for drum rolls. Many vsts don't have built in roll articulations, but with modern instruments you can do it manually. I'd like a rule similar to the custom trill rule. Once triggered it would play the same note repeatedly for the duration of the note. The length of the repetitions should be user definable, it should have a velocity randomness parameter and a length randomness parameter. Using these 3 parameters it should be possible to make a realistic drum-roll/trem.
by phillipcartwright on Wed Feb 25, 2015 12:22 pm
I made a similar request on the old forum year(s) ago. This should also apply to melodic tremolos (tremolos between 2 notes generally larger interval size than just a trill).
by martinkutschker on Sat Feb 28, 2015 9:48 am
by michaelmyers1 on Mon Mar 23, 2015 5:50 pm
phillipcartwright wrote+1
JBL LSR310S subwoofer
Notion 6 + Studio One 5 Pro
http://www.tensivity.com
by michaelmyers1 on Wed Mar 25, 2015 8:20 pm
Trills as well.
cron
